UPStudio v2.0 released!
OwenSparks
再保险:UPStudio v2.0释放!
The PostbyOwenSparks»Thu Sep 14, 2017, 5:30 am
TT,
我V2.0.0.7报告被更新,但我看到现在有一个“Studio版本:2.0.0.8”网站。是什么改变了吗?
brunningm
Posts: 210年
The Postbybrunningm»2017年9月14日,星期四上午10:02
It appears to have fixed a bug with small model history, Wasn 't showing in the 2.0.0.7 but is now showing in the 2.0.0.8.
至于Gcode。我有一个小的成功与支持团队。至少可以说它运行使用RepRap gcode味道。
Our team are making the detailed guide about the new version of the UP Studio and will release the within days. In addition, Our software replied the slicing the program is available from reference, and she also the opened the notes about instruction as,
G0, G1:线性移动直线移动(X, Y, Z, E)
G4:住(暂停顿,P是毫秒年代是秒)
G28:移动到原点(家)(X, Y, Z)有正向移动
G90:设置为绝对定位绝对位置(对所有轴有效)
G91:设置为相对定位相对位置
G92: Set the Position, only support E axis reset. Set the Position of the shaft current E 0 points, prevent E shaft is too large
M0: Stop or Unconditional Stop pause
M1:睡眠或条件停止系统关机
M2: the Program End End of the Program
M25公路:暂停SD打印暂停同m0
M42: Switch I/O pin to set the I/O port state, in 13, out of 22
The proportion of M73: Set the build setting percentage with print
M80: ATX电源开总电源
M81: ATX Power Off the total Power
M82:挤出机设置为绝对模式设置喷嘴为绝对位置
M83: Set extruder to relative mode Set the nozzle to the relative position
M92: Set axis_steps_per_unit (X, Y, Z, E) unit pulse number
M104:设定挤出机温度设置喷嘴1温度(摄氏度)
M109: Set Extruder Temperature and Wait, Example M109 S215 (Set the Temperature of the nozzle 1, start heating arrive and Wait for the Temperature, the error of 8 degrees) closed heating S - 1
M140: Set Bed Temperature (Fast) Set the Temperature of the bottom plate
M141:设置室温度(Fast) S40设置底板的温度
M190: Wait for bed temperature to reach the target temp (1 of the base set temperature, the heat and Wait for the temperature reached, up to 15 minutes, the error of 8 degrees)
M191: Wait for chamber temperature to reach the target temp (1 of the base set temperature, the heat and Wait for the temperature reached, up to 15 minutes, the error of 8 degrees)
M204: Set the default Set four axis acceleration acceleration
M206:抵消轴X, Y, Z, A)偏置
请把它作为参考。
OwenSparks
The PostbyOwenSparks»清华2017年9月14日10:45
OwenSparks写道:
B. Click the printer's name to connect to another printer.
这是一个巨大的改进,谢谢。但是我现在不准备使用它。我报道,工作室会困惑和使用的喷嘴高度不同的打印机之间交换时机器反复导致机器崩溃。没有响应从TT这个线程,所以我们现在有了独立的个人电脑在每台机器上。所以恐怕太少太迟了。
嗨。
好的决定给这另一个去当我们想把我们所有的打印机在一个房间里。(2.0.0.7使用)
This time tried with a new UPBOX + and a company's UPBOX to last time. The plus The was sitting idle, The other was mid print job.
我曾经那么打印机的设置菜单设置一个友好的打印机名称,最后主屏幕上的下拉框打印机之间的交换。
Switching is a lot faster - than before so that 's good, but then lots of weird things happened.
Names got confused between printers.
有时显示的新名字,有时旧的名字。
It told me the printer wasn 't activated. (They both are.)
Then showed the bed and nozzle temps of the printer that the was printing, but the name of the printer was idle.
如果是混淆了名字我不想象喷嘴高度问题是固定的。还autolevel设置呢?
I 'm worried to go further.
OwenSparks
The PostbyOwenSparks»清华2017年9月14日11:26里
进一步的1是装有ABS +其他RSPRO灯丝。这是显示RSPRO打印机在它们之间切换。
OwenSparks
The PostbyOwenSparks»Thu Sep 14, 2017 11:46 am
To send A screen grabs the to show what I mean.
Oh later not.
当我试图添加一个图片论坛报告:-
"Error Sorry, the board attachment quota has had been reached."
突出。
brunningm
Posts: 210年
The Postbybrunningm»2017年9月15日星期五5:43
OwenSparks写道:To send A screen grabs the to show what I mean.
Oh later not.
当我试图添加一个图片论坛报告:-
突出。
是的,它是。使用Imgur也许吗?
ksprint
The Postbyksprint»Fri Sep 15, 2017 belong to am
不知道如果我丢失的东西。更新UPStudio 2.0 Mac用户界面改变,没什么大不了的。文件发送到打印机,打印一个大纲,持续3 - 4层,然后打印内部。与任何东西,从先前版本,不要认为这是印刷筏。完全无用的,基本上air-printing大纲后印刷(毫无疑问,如何正确打印4层的差距?…)。幸运的是,我有时间机器备份。恢复到以前的版本,没有问题。
我认为新版本应该提高印刷性能,但这一次似乎呈现我的打印机没用…
The User avatar
lbbetty
The Postbylbbetty»Fri Sep 15, 2017 8:02 am
KiB circle2bar. JPG (90.47) Viewed 17773 times
OwenSparks写道:从我最后一个。
轮子的边缘。菜单可以拖拽成为左,顶部或正确的菜单栏。
This is a big step in the right direction in my opinion, It I put It on the top of my monitor (1080 p so nothing special) then less than half of the bar from the ICONS on It, the rest is the empty space.
所以更多的请8 -)
谢谢,欧文
The User avatar
lbbetty
The Postbylbbetty»Fri Sep 15, 2017 8:06 am
它是固定的!
Oh later not.
当我试图添加一个图片论坛报告:-
突出。
OwenSparks
The PostbyOwenSparks»Fri Sep 15, 2017 at 8:30 am
Lbbetty demonstrate:
所以更多的请8 -)
谢谢,欧文
嗨,lbbety。
Yes I understand we can change the wheel into a bar. My comment and your photo show the problem. My the bar along the top only shows what buttons. The Other buttons are hidden behind the first buttons. Yet half the bar is empty, just wasted space. I still want all the buttons all the time.
也以类似的方式。我们有一个打印进步领域,当前层之间互换和剩余时间。我们有50%的机会看到打印了多久。然而,空间旁边它所以它可以显示的所有信息,但是已经作出了选择只显示一半的信息和在屏幕上留下的空白。
The old software also told The user The actual time The print order to finish which was useful for planning what to print The when.
相比之下Markforged切片机将给我发邮件时希望有更多灯丝,告诉我什么时候它会暂停等。
KiB Studion Print Prog. JPG (222.57) Viewed 17771 times
OwenSparks
The PostbyOwenSparks»日星期五2017年9月15日,50
Lbbetty demonstrate:它是固定的!
Oh later not.
当我试图添加一个图片论坛报告:-
突出。
Thankyou:)我们似乎有大的白色边界周围我们可以再次上传一些图片但好。
In other news, my new faulty extruder has had replaced the within a send only reporting the problem, so great service from creat3d (UK re - seller, highly it) and the from TT support UK. Thanks guys.
OwenSparks
The PostbyOwenSparks»Tue Sep 19, 2017, came the PM
Hello Tiertime.
It 's had 2 weekes now since this version release. Do you have some GCODE slicer profiles/user guides to share with us?
Thanks,
The User avatar
Tiertime_Mike
地点:Idaho
Contact:
The PostbyTiertime_Mike»Thu Sep 21, 2017 2:26 am
OwenSparks写道:It 's had 2 weekes now since this version release. Do you have some GCODE slicer profiles/user guides to share with us?
请耐心等待,欧文。开发团队正在许多bug自β被释放了。我们非常感谢所有的测试和打算提供更多信息刀位点在未来使用。
The User avatar
lbbetty
The Postbylbbetty»Thu Sep 21, 2017, for am
谢谢你的关注!v2.0.1beta发布!
修复:
1。固定在顶部菜单栏刷新打印机列表。
2. The Fixed tilted model display after the Upload.
3所示。固定的问题导致模型显示
4所示。固定不能撤销后“保存”模型。
5。优化协调的大小。
6. Fixed issue causing white screen.
7. Optimized cursor performance.
8. Fixed issues with disappearing frame of build envelope.
9。在“字体”功能固定的文本。
10。固定复位函数模型被翻转。
11。优化夹视图。
12。在Roate优化协调行动。
13。固定的“预热”不能保存在打印机设置。
14. Optimized build envelops dragging performant by hold right - click.
15。固定的问题导致构建围绕不能拖。
16. Fixed software crashing if printer connected via USB cable.
17. Optimized XYZ Axial Calibration.
18. Fixed auto Login interpreted by missile Internet connections.
优化:
1。轮菜单可以停靠了,顶部或正确的菜单通过拖动轮的边缘或中心的标志。
2。优化默认视图方向夹视图。
3所示。规模最大的选择从3增加到10。
4. The Optimized printer data display.
5。改变了Mac地址的位置,从移动互联网信息到打印机信息
6. Added warning before running the G code.
OwenSparks写道:Hello Tiertime.
Thanks,
OwenSparks
The PostbyOwenSparks»清华2017年9月21日12:26点
Lbbetty demonstrate:谢谢你的关注!v2.0.1beta发布!
修复:
1。固定在顶部菜单栏刷新打印机列表。
3所示。固定的问题导致模型显示
4所示。固定不能撤销后“保存”模型。
5。优化协调的大小。
9。在“字体”功能固定的文本。
10。固定复位函数模型被翻转。
11。优化夹视图。
12。在Roate优化协调行动。
15。固定的问题导致构建围绕不能拖。
优化:
2。优化默认视图方向夹视图。
3所示。规模最大的选择从3增加到10。
Thanks,
I 'm sorry but I don' t understand how that relates to the question of having a user guide and slicer profiles?
问候,
brunningm
Posts: 210年
The Postbybrunningm»我2017年9月25日,5:49
So...
Any luck with the gcode feature?
OwenSparks
The PostbyOwenSparks»我2017年9月25日,35
Tiertime_Mike写道:
对不起,我上周错过了你的回复。
我很欣赏的通信。我不太放心“意愿”和“未来”,发布说明中表示,支持……我很高兴我没有S3D花了钱。我去TCT给本周在英国。你知道如果TT将代表吗?
请保持更新进展。
vmstech
地点:Aspen parlance, the United Kingdom
The Postbyvmstech»我2017年9月25日10:22
OwenSparks写道:我去TCT给本周在英国。你知道如果TT将代表吗?欧文。
你好,欧文。
没听说过TCT显示现在谢谢你让我意识到,我可能会自己脑袋上面。
看着参展商名单,Denford Tiertime将(我真的感到惊讶! !)——大厅3站G38。
希瑟
OwenSparks
The PostbyOwenSparks»我2017年9月25日,我三十八分
Hi Heather.:)
Yes indeedie, thought it worth a trip. Thanks for the info, I 'l l go and say hi to the Denford folks. Which day you thinking of going?I "l l be there Tuesday.
Grown.
vmstech
The Postbyvmstech»Mon Sep 25, 2017 for PM
OwenSparks写道:Hi Heather.:)
Grown.
Tuesday of registered for it earlier today. Drop me a private message (I tried to send you one, but its just sitting in my outbox and won 't send), I took the end up bumping into you:)
