Original Post://www.wenxuezihua.com/community/viewtopic.php?f=50&t=56511&sid=34fff4546677726cbb11373c79b55a0e
Hi All,
Just wanted to share the fantastic quality that I’m getting from my UP300, that is some cases outperform my resin printer.
That I can print 40TPI threads at this scale is amazing - the tolerances of the UP300 are truly fantastic, and the finish is excellent - no obvious defect anywhere on the model, no significant signs of the print head shaking with right angle turns. Clean sharp threads at 600 micron spacing, with coverage over most of the surface.
I never expected the threads to come out this well on the first attempt ! My old UP Mini just wasn’t even capable of printing the 600 micron spacing threads and struggled with the 800 micron spacing threads. ( both are actually imperial threads, 32 and 40 tpi )
David.
Top
Daniel
加入:Sun Nov 11, 2018 12:12 pm
PostbyDaniel» Fri Nov 16, 2018 1:29 am
Hi David,
Did you need to go through a manual bed level procedure prior to the first print?
Did you use ABS and standard settings when printing your 40TPI threads?
Top
BigE79
加入:Fri Oct 26, 2018 9:18 pm
PostbyBigE79» Fri Nov 16, 2018 5:43 am
Hi David,
Thanks for sharing, those threads look great.
I’ve had some issues with internal supports falling over and causing print failure but apart from this I’m also getting excellent results with my UP300 and I’ve been printing allot.
Have you tried 50um layer height yet? You need to use the 0.2mm Nozzle for this. I’m keen to give it a try soon but so far I haven’t changed out the nozzle.
Top
Owen Sparks aka Marksman
加入:Tue Mar 15, 2016 9:56 am
PostbyOwen Sparks aka Marksman» Fri Nov 16, 2018 7:52 am
Howdy, that’s a great looking part.
Can we have a some context please? Overall dimensions, material used, what is it and what does it do etc?
Cheers,
Owen S.
Top
cj7hawk
加入:Tue Dec 25, 2012 7:52 am
Postbycj7hawk» Fri Nov 16, 2018 9:09 am
It’s a lower part from an AN/PVS-14.
One of these;
And yes, it’s fully functional and replaces the part entirely.
100微米层,黑色ABSsitting around in the humidity for months, 99% infill, though typical wall is around 1 to 2mm thick.
David
Top
PostbyOwen Sparks aka Marksman» Fri Nov 16, 2018 9:14 am
Many thanks, great project!
Owen S.
Top
