That’s great!
Now… can you check the upper nozzle where all the problems seem to arise.
This is what the mating end, upper nozzle…throat should look like:
This has been cleaned of debris.
Brent
---- excellent, and the white tube condition?
----I use a piece of filament and insert from top to make sure there is absolutely no friction, preferably the largest diameter…you may have to measure the filament to find the thickest area. I use a filament that is .178mm in diameter.
----the tube must be white as white can be
----oh, I did not see a bowden setup in the past vids?
----I mean the white tube inside the throat
----are you using a piece of filament that has the gear markings as when it passes through the extruder motor area?
---- what I mean is, as we are testing stuff, you need to use a piece of filament thathas正确模仿灯丝th的咬痕at normally passes through…and if there is no white tube, has this nozzle been re-engineered from the factory and the use of the white tube is no longer necessary?
----I’f there’s no PTFE white-tube in the upper nozzle throat this will over-heat the filament and will quickly disrupt the flow of filament. There’s a ridge the filament must get past if there’s no white-tube.
