Are your material profiles configured with the 0.2mm nozzle?
That should be the issue here. Check the material profile that was selected,when你改变喷嘴大小的菜单。
You can add different nozzle sizes to your custom material profile easily.
If you get stuck with the settings, copy, or base some of your settings off the respective base Tiertime material.
