的netwrok setting in the configuration section is only used for function that need to communicate with our server on cloud. For example login user account on the software and submit feedback to support team from the software. It has nothing to do with WIFI connection to computer.
The 2 options refer to 2 difference way to connect to our server, usually both method should work when users faced network issues, typically result in login failure, they can switch between these 2 options and try again, likely the issue will be resolved.
Comments
0 comments
