Speed (mm/s): User could define the subset of speed settings.
Profile |
mm/s |
Print speed of Perimeters |
我nner Profiles |
mm/s |
Print speed of Inner Perimeters |
Bottom and Top |
mm/s |
Print speed of Bottom and Top |
填满 |
mm/s |
打印速度的填充 |
支持 |
mm/s |
Print speed of Support |
支持Hatch |
mm/s |
Print speed of Support Fill |
Jerk |
Print speed of Short path |
Jerk Length |
mm |
Define Max. Length of short path |
Raft |
mm/s |
Print speed of raft layers |
Raft Base |
mm/s |
Print speed of first layer of raft |
Jump |
mm/s |
Speed of jumps (non- printing movements of extruder) |
Temperature Tune
User could adjust the print temperature for particular entity. The range for adjustment is the +/-20C from the basic print temperature.
Adjustable entities:
- Perimeter
- infill
- 支持
- Raft
支持Peel
Bond Strength(%): define the stickiness between part and support.
Extrude Scale
Extrusion scale of perimeter, value larger than 1 means increasing extrusion amount, value smaller than 1 means reducing extrusion.User could define the subset of of extrude scale settings, adjustable entities:
- Perimeters
- 我nner Perimeter
- Top
- Bottom
- 我nfill
- 支持
- Jerk(not supported yet)
- Raft Base
- Raft
Seam Optimization
Please read this article
Speed Reduction
Slowest Speed: Slowest speed for slowing down short perimeters
Short Perimeters: the value to determine whether to slow down as short perimeter
Minimum Layer Time: minimum time a layer must spend, so that to ensure enough cooling for small features.
First Layer Speed: Slow down the first layer speed for the print job, for improved first layer adhesion.
Other Options
Platform Preheat: preheat platform for maximum 15 minutes before printing. Print will start if target platform reach before 15 minutes.
Sleep: De-initialize the printer after the print job finishes.
Comments
0 comments
