UP mini 2 ES
3D Printer Accessibility Redefined
$699
- Ethernet
- USB Stick
- WI-Fi
- Tiertime Print Queue
What's new in UP mini 2 ES?
The UP mini 2 ES is a more advanced mini 2 with improved hardware and software.
It inherited its predecessor’s full enclosure with built-in HEPA and activated carbon filter.
Coming with the feature like Tiertime print queue,
it fits more in the office,
classroom and home environments.
Touchscreen Control
Upgradeable System
Editable Printer IP Address
Print Job Storage
More Connectivity
Ethernet Socket
Extra USB Port
Upgraded
An updated control screen verses the original mini 2, it has more features and functionality, plus the ability to be enhanced via future upgrade-able touchscreen system.
3D Printing Workflow
Enhanced
An Ethernet socket allows you to connect your printer to a wired Local Area Network for maximum security.
HEPA and Activated Carbon Filter
3D printing certain materials such as ABS can generate potentially harmful
UFP and VOC emissions. The HEPA and Activated Carbon filter effectively
reduce these toxic elements, known to be triggers for those suffering from
哮喘和其他肺部疾病。
Specifications and Warranty
Printer |
Printing Technology | MEM (Melted Extrusion Modelling) |
Extruder | Single |
Nozzle Diameter | 0.4mm |
Extruder Maximum Temperature | 299℃ |
Extruder Maximum Travel Speed | 200 mm/sec |
XYZ Accuracy | 5, 5, 5 micron |
Connectivity | USB Cable, Wi-Fi, LAN and USB Drive |
Display | 4.3″ Full Colored LCD Touchscreen |
Build Volume | 120 ×120 ×120 mm (7″ x 9″ x7.8″)(XYZ) |
Printed Object Accuracy | ±0.1mm/100mm |
Layer Resolution | 0.15/0.2/0.25/0.3/0.35mm |
Build Plate Maximum Temperature | 70℃ |
校准and Levelling | Auto Nozzle Detect |
Build Plate Surface | Perf or Flex, Heated |
Pause to Change Filament Type | Yes |
Filament | UP Fila ABS, ABS+, PLA, TPU and more |
Filament Diameter | 1.75mm |
Filament Spool Compatibility | 500g |
Compatible with 3rd Party Filament | Yes |
Software |
Software | UP Studio Version 2.5 or above |
Supported OS | Windows 7 (SP1) or higher (32 bit and 64 bit) Mac OS 10.10 |
Hardware Requirements | OpenGL 2.0 At least 4GB of RAM |
Importable File Formats | .up3, .ups, .tsk, .stl, .obj, .3mf, .ply, .off, .3ds |
Preview Support Structures | Yes |
Editable Support Structures | Yes |
Physical Dimensions |
Machine Dimensions | 255 x 365 x 385 mm (19.3″ x 20.5″ x 18.1″) |
Net Weight | 52kg |
Shipping Box Dimensions | – |
Shipping Box Weight | 7.5kg |
Power Requirements |
Power Input | 110-240VAC,50-60Hz,90W |
One-Year Manufacturer’s Warranty
Rest easy knowing your investment is safe. Tiertime warranties all UP printers against manufacturing defects for a period of one year from the date of purchase.
